Displays DoS protection configuration and state.
| detail | Specifies to display statistics in addition to configuration and state. |
N/A.
trusted.
notify.
alerts.
The following command displays the DoS protection settings for the switch:
show dos-protect
The following is sample output from this command:
dos-protect is disabled dos-protect settings: interval: 1 (measurement interval secs) acl expire time: 5 (secs) trusted ports: no trusted ports configured type L3-Protect: notify threshold: 3500 (level to log a message) alert threshold: 4000 (level to generate an ACL)
The following command displays detailed DoS protection settings for the switch:
show dos-protect detail
dos-protect is enabled dos-protect settings: interval: 1 (measurement interval secs) acl expire time: 5 (secs) trusted ports: 1:2 type L3-Protect: notify threshold: 3500 (level to log a message) alert threshold: 4000 (level to generate an ACL) dos-protect statistics: trusted: 1301 notify: 0 alerts: 0
This command was first available in ExtremeXOS 11.1.
